dursunturk
#1 Posted : Monday, November 12, 2018 5:34:49 PM(UTC)
dursunturk
Hello there
I have the Aja IO 4K right now. In this system I want to send different visuals for each sdi port I want to use the external outputs contained within Vmix
for example
SDI1: Flag
SDI2: Visual
SDI3: Movie
SDI4: Presentation
and I would like to actively use this event continuously, can you please help?
#2 Posted : Monday, November 12, 2018 6:28:10 PM(UTC)
vMix only has 2 external outputs for external rendering as indicated in the documentation
https://www.vmix.com/help21/ExternalOutput1.html
Check Newtek Connect Pro which might be able to do what you want
https://www.newtek.com/connect/connect-pro/
Guillaume
