guztavo
#1 Posted : Sunday, October 28, 2018 4:10:11 AM(UTC)
guztavo
Hi!
I want to know why can be that if i move from 720p25 project to 1080p25, when i change the setup of my camera, the image works for a few seconds and then just freeze.
You can see here the test:
If i reset the input, the image appears again. But after a few seconds, freezes again.
I work with a Blackmagic Deckling, getting video from HDMI.
In 720p25 works fine.
Using last vMix version.
Thanks!
Barney Box Lane
#2 Posted : Sunday, October 28, 2018 9:24:27 PM(UTC)
Barney Box Lane
your camera aspect ratio and frame rate needs to match the project aspect ratio and frame rate
guztavo
#3 Posted : Monday, October 29, 2018 9:55:53 PM(UTC)
guztavo
Thanks for answering.
Thats not true at all. Its true that same aspect ratio and frame size and rate helps a lot with CPU and GPU usage but one of all vMix advantages is that you can use multiple sources with different frame rates and sizes.
In the other hand, you can see that vMix get the camera. A few seconds later just freezes.
Thanks! And sorry for my english. Im writing from cellphone with spanish correction.
Regards
prass
#4 Posted : Thursday, November 1, 2018 2:00:04 AM(UTC)
prass
Was thanked: 3 time(s) in 1 post(s)
What is your computer specification?
guztavo
#5 Posted : Friday, November 9, 2018 1:38:02 PM(UTC)
guztavo
Sorry for the delay!
Core i7-2600K LGA1155 3.4GHZ
RADEON HD 6850 775M 1GB DDR5 HDMI DVI VGA
Motherboard ASUS P8H67 B3
RAM 12GB
vMix: Lastest.
It is an old setup but works really fine!
ask
#6 Posted : Saturday, November 10, 2018 1:14:19 PM(UTC)
ask
Just a guess, but your graphics card is probably the culprit/
richardgatarski
#7 Posted : Saturday, November 10, 2018 9:40:02 PM(UTC)
richardgatarski
In my experience Blackmagic's devices demand that you specify the exakt camera resolution and frame rate in the Input. Other cards (eg Magewells's) automatically adapts if the settings are changed in the camera.
