Can I show ONLY my 6 video sources on monitor 2?
Is it possible to display my 6 video sources on my secondary monitor (display number 2), without also showing the Output and Preview windows on the secondary monitor? I want to display ONLY my 6 video sources.
Thank you for a prompt reply, as I am under a time crunch.
@ skyready
I would suggest adding a Blank Colour Input and put the 6 video source Inputs as MultiView Overlays and then select that new Input as your "Fullscreen" Source.
Joined: 11/1/2018(UTC) Posts: 21   Location: NY Thanks: 4 times
I've used this before. DECIMATOR DMON-6S 6 Channel Multi-Viewer with HDMI & SDI Outputs https://www.bhphotovideo...RoCFmAQAvD_BwE&smp=yA little pricey at $595 but it allows you to use an inexpensive HDMI monitor as your multiviewer and displays embedded audio levels. Great as a confidence monitor. This helped us troubleshoot lost audio from a camera (fan ambient mic), it immediately showed us the problem was at the camera when we saw no levels, not somewhere downstream.
