Using Dante input -monitoring
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
I have a Dante enabled mixer and am planning on sending this directly to my video rig with vmix. This will give me control of each channel of audio coming into the system, for granular control. What I am not sure of is how to monitor the signal for a headphone mix.
I need something with USB input only and a headphone jack for monitoring. I would like the sound of this to be as close to what is going out as possible.
Any ideas?
Thanks.
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Check out Dante VIA and Dante Controller software ... it may do what you need.
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
mikekay, You need to specify a little bit more about your audio setup. What do you mean by sending "this" and "monitor", for example do you need to Solo inputs at the mixer end or just listen to what vMix sends out.
