Bug on recording - NO RECORDING
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi! I want to share with you a bug that i found on vMix with recording setup. I have changed Windows and added a new SSD for runing the system. The result, the units letters changed. So now I do not have a D unit. Last week i opened to preset created on last setup of this machine (before changing Windows), so when i pressed RECORD, the popup window shown the setup. As ussual (my bad), i accepted that the recoding was going to be done at D:\PGM\ (i forgot the change of units letters), so vMix start recording on the old path that doesn't exist anymore. When i tried to find the files, they just did not exist. But the main window was the REC indicator fine, and even the CPU usage increased as usual, so i did not see something strange. I solved downloading the Youtube feed.
Using lastest version of vMix. Thanks
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
If the recording path does not exist, then vMix will revert to the default recording folder in Settings. This is usually Documents\vMixStorage, so you should find the recording there.
Martin vMix
 3 users thanked admin for this useful post.
Hi Martin,
You were right. The recording was there. My bad. Regards!
