Possible to show transparent graphics from browser window?
Hi
I'm new here and want to ask if anyone can help on this issue.
I'm trying to put a scoreboard on top of a live feed in Vmix and want to show transparent (dynamic) graphics. Is it possible to send a signal with alpha channel (NDI??) from the browser to Vmix?
As of now I only input the browser page and key the background color out, but this results in ugly artefacts on some graphics.
Thanks for the help. Best regards from Germany
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Yes.
Both SDI and NDI can use transparancy information.
thanks for the info, but I know, that NDI can use transparency, but how can I get transparent graphics from a browser window over into Vmix?
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
if you use the native browser/webpage input in vmix and simply have no background in your webpage it is then automatically transparent
Originally Posted by: Vuurmannetje  Yes.
Both SDI and NDI can use transparancy information. SDI does NOT contain any alpha info.
Thank you so much for your information and tipps. I will try to figure out a way to integrate the Vmix browser into this project.
