Doug
#1 Posted : Tuesday, September 3, 2013 11:07:29 AM(UTC)
Doug
Hello all... Ran across an issue and am wondering if anyone else has experience this in vMix 10? I set up a bunch of shortcuts for a sportscast this past weekend and during the middle of the game, found the scoreboard shortcuts +1, -1 for the home and away teams had somehow shifted to the next preset down causing the score change feature to stop working. Several other shortcuts had done the same. As this occurred while the game was being recorded and I was by myself, I had to wait til half time to reset the shortcuts. They were fine after that. Any ideas?
Shot 2 games this weekend and only had that happen once.
-Doug
thanks 1 user thanked Doug for this useful post.
Adriankey4 on 9/3/2013(UTC)
Doug
#2 Posted : Friday, September 6, 2013 7:00:06 AM(UTC)
Doug
Also found that my separate audio input would shut off when I used a replay from the video delay...leaving me with no game audio for portions of the contest. Have another game this Saturday. Will try again.
#3 Posted : Friday, September 6, 2013 8:58:33 AM(UTC)
Hi Doug,
If you want audio from a particular input to run all the time, turn of Automatic Audio Mixing in the input settings.
By default, shortcuts are setup by input number, so if you reload a preset you may need to check the shortcuts to make sure they are assigned to the correct input.
As an alternative you can set a shortcut to "Local Only" which will be saved inside the preset and be fixed with the assigned input.
Doug
#4 Posted : Friday, September 6, 2013 9:55:46 AM(UTC)
Doug
Thanks Martin. I will check all those things out. As always, love vMix!
Similar Topics
Shortcut issue when doing DataSourceSelectRow function (General Discussion)
by nidarosvideo 4/12/2022 7:00:34 PM(UTC)
Data Sources Shortcut Issue (General Discussion)
by DavidJChalmers 4/8/2022 9:00:17 PM(UTC)
shortcut issues (General Discussion)
by VW001 6/24/2021 3:17:15 AM(UTC)
