Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
Jboze: 1.- Yes, the title has reading from a Excel sheet ( all lineups ) 2).- The Excel have a few formulas 3).- Each field on XAML title has linked to an excel field 4).-the button foward and backguard on UTC use scripts vmix commands for changing over vmix titiling
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
chococrispis35 wrote:Jboze: 1.- Yes, the title has reading from a Excel sheet ( all lineups ) 2).- The Excel have a few formulas 3).- Each field on XAML title has linked to an excel field 4).-the button foward and backguard on UTC use scripts vmix commands for changing over vmix titiling I need to say that you made a great job with UTC controller Best regards
elgarf :
The Path select button in Text Field widget , Can it also be blocked when you select Look and only work when you unlock?
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
chococrisps35, yes, I think it can be.
chococrispis35 wrote:Jboze: 1.- Yes, the title has reading from a Excel sheet ( all lineups ) 2).- The Excel have a few formulas 3).- Each field on XAML title has linked to an excel field 4).-the button foward and backguard on UTC use scripts vmix commands for changing over vmix titiling Man, there is so much more I need to learn about vMix and UTC. How do you have the XAML titles liked to the excel fields? Do you have it converting rows to columns within vMix? When I was attempting it before that was the only way I could map different parts of XAML titles to cells. I suppose I have a lot to learn about Excel too.
yes Jboze, xaml linked to excel, the same excel loaded 3 times and convert first row to columns and other converto row to columns, i have few months learning excel on youtube tutorials and reading this forum, same with blend for animated titles
chococrispis35 wrote:yes Jboze, xaml linked to excel, the same excel loaded 3 times and convert first row to columns and other converto row to columns, i have few months learning excel on youtube tutorials and reading this forum, same with blend for animated titles Can you put some good links of blend video tutorials for us here? thx
Quote:Can you put some good links of blend video tutorials for us here? Please guys no off-topic comments here. UTC only ! Blend is already discussed in others sections of the forum
DWAM wrote:Quote:Can you put some good links of blend video tutorials for us here? Please guys no off-topic comments here. UTC only ! Blend is already discussed in others sections of the forum I didnt mean here on this topic. I was thinkg to make another topic for blend. best regards
I've gone through most of the pages here and searched, can't seem to find a concrete solution to the NDI Monitor. I downloaded the external data container, added it, and I can select "vmix output 1" in the dropdown, but I can't get actual video to display. I'm surely missing something probably obvious!
@spencerm24, is this button active? elgarf attached the following image(s):  1.png (14kb) downloaded 53 time(s).You cannot view/download attachments. Try to login or register.
Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
Hi everyone! I have seen at some video about UTC, big buttons, that higher above standart. I did not pay attention to it, but today I want to make such button, and it's impossible to do by draging the mouse. Please share a secret?
UPD: Foud. Need to edit by hands saved preset. or push buttons up and down. )))
@tkachuk.alex, try this buttons. elgarf attached the following image(s):  T0.png (12kb) downloaded 37 time(s).You cannot view/download attachments. Try to login or register.
I used UTC yesterday for graphics in combination with ATEM. Works perfect Once again thank you elgarf!
Sorry for my English ... Please tell me how to implement the change team colors through UTC. How do I enroll it in xaml? Now it's displayed through a static picture and text fields
Quote:how to implement the change team colors through UTC? There are different methods to this. If you want to control it live from UTC, you can use the SetImage or SetImageNative function which allows to call different images in a placeholder? You will need to prepare images with each color before, if you want orange you must have an orange image to call, if you want blue you must have a blue image to call. Then it's just a matter of changing the url of the image to use, you can do this from a list widget for example I have some examples of this in the tutorial I did for UTC https://forums.vmix.com/....aspx?g=posts&t=9393YOu can also use datasource either in vMix or UTC to create a "table" which associates the team names with their color images. When you select a team name, it calls the right colored image to use. Another solution is pure XAML coding and won't use UTC at all. For example your title can use a font symbol for which you select a color. As if you are writing in red or blue. FOr this you just have to open Title Designer before the game and change the color so that it matches the team color. Hope this helps Guillaume
Rank:: Member
Originally Posted by: Snooker Loopy  @elgarf
Yes, I only need to see the scoreboard. I'm not sure how to achieve sending out Multiviewer (2x2) through NDI though. Could you explain a little what I need to be looking for please? Hi elgarf, Well, I tried and tried to find a way to send multi-view to NDI but can't see any way of doing that in the VMix level that I have although I did manage to find a way round the issue by sending 'Fullscreen' to the external monitor along with UTC and then re-sizing UTC so I could see the scoreboard underneath - Yippee - problem solved. I do have another issue however and that is:- Is it correct that when I re-open UTC and load an already saved control file it is necessary to refill the Title Mapping 'Input' field for each and every component that I have previously configured? I've tried opening my VMix preset before and after the UTC preset and done 'Update State' several times but I always end up having to go through and manually reset all 24 components :-( Thanks in advance for any help
Originally Posted by: Snooker Loopy  I do have another issue however and that is:- Is it correct that when I re-open UTC and load an already saved control file it is necessary to refill the Title Mapping 'Input' field for each and every component that I have previously configured? I've tried opening my VMix preset before and after the UTC preset and done 'Update State' several times but I always end up having to go through and manually reset all 24 components :-(
That's strange, because UTC should save info about mappings. There can be issues if you move/scale input, but I think you doesn't do that. Are you sure you loading same preset?
I had the same problem before if I add new input in vMix or change titles, input numbers etc Now I am careful when adding something new and I didnt have any problems. Everything works perfect
Rank:: Member
Thanks elgarf and Siroki
I didn't make any changes but thinking back I do remember locking UTC on the last stream to make sure that another operative would not inadvertently make changes.
When it came to the end of the stream I clicked 'lock' again so I could close the program not realising that it would unlock all the widgets at the same time (which had been previously locked). I now realise that if UTC is closed with any/all widgets unlocked then it seems to lose the mapping. I'd assumed that by saving the project it would automatically save the mapping(s).
If it were possible, my wish list would include:
1. The option to lock/unlock all widgets with one click independently of locking/unlocking the program 2. That the program would resize automatically when opening an existing project
Also, any ideas as to why three laptops that I use insist on asking to register filters each time UTC is started but the fourth one doesn't?
