MikeBenke
#1 Posted : Thursday, October 11, 2018 8:16:49 AM(UTC)
MikeBenke
Is it possible to send multiple variables in a command through the Web API (GET) commands? I'm doing it wrong if it is possible... see below example that is attempting to turn off a running overlay and resume play on a replay clip.
http://127.0.0.1:8088/api?Function=OverlayInput1&Input=2;Play&Input=-1
#2 Posted : Thursday, October 11, 2018 8:18:49 AM(UTC)
No
But you can send multiple commands as a sequence. Same effect
http://127.0.0.1:8088/api?Function=command1&Input=x
http://127.0.0.1:8088/api?Function=command2&Input=x
http://127.0.0.1:8088/api?Function=command3&Input=x
MikeBenke
#3 Posted : Thursday, October 11, 2018 8:29:59 AM(UTC)
MikeBenke
stupid question.. how do you send a sequence?
#4 Posted : Thursday, October 11, 2018 9:29:24 AM(UTC)
From any code for example... ASP, VB, PHP, Ruby, Java and so on... or simply from a script using shell, terminal, etc...
Or you can use special tools like vMix UTC or vMix Panel Builder...
Or you can use internal vMix scripting feature as well as triggers and shortcuts in some cases.
If you're thinking about sending commands from within your own tools, I don't know which programming interface you're using but anyway it's just a matter of code
Guillaume
MikeBenke on 10/12/2018(UTC)
MikeBenke
#5 Posted : Friday, October 12, 2018 8:34:11 AM(UTC)
MikeBenke
Thanks for the Direction DWAM! I'll share it with the guys who write the code!
Mike
Guest (4)
