Monitoring the Actual Stream
Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
I did a show using vmixcall. From my end everything was perfect....both video and sound were great. When I checked out the recording (and streams) after the fact, the guests volume was ridiculously low. I am currently monitoring my self from my Mackie mixer headphone jack. My phone system is dependent on the mixing board to recieve calls.
Any suggestions on how I might be able to hear the actual mix as it goes down?
Monitor from the actual PC headphone output, thats the vmix output and is a better representation of what is going out. Also, keep an eye on the level meters on the output monitor.
Since my microphone and my caller phone system are attached to my mixing board, I can't hear any of that if I plug into my computers headphone jack. Any other ways of doing this?
michaelrb wrote:Since my microphone and my caller phone system are attached to my mixing board, I can't hear any of that if I plug into my computers headphone jack. Any other ways of doing this? It depends on whether you've got the right sort of mixing board for this type of job. You need one where you can set up a monitor mix (for your headphones), fed via a post-fade send on your mic channel(s), which is independent of the main output (or whatever output is being sent into vMix). You would also need to use one of the A or B aux outputs from vMix to send everything else that's in vMix's main output mix into a spare channel on the mixer, and use a pre-fade send of that signal into the monitor mix. This would need an element of calibration to set the monitor mix so that what you hear will exactly correspond to what is going out via the vMix main output. It might be worth hiring an audio engineer (with the necessary test equipment) to come and set this up for, if your mixer has such capability. Alternatively, you could use a second small mixer, with a couple of inputs, to perform the same function, generating a calibrated mix of the main mixer output and the other audio from vMix. However, rather than depending on what you hear, I'd also suggest the use of audio metering that can be placed near your eyeline, be that software meters on a screen, or traditional hardware audio meters (taking a feed of the main output from vMix). You might also wish to experiment with my NDI NoAudioMeter software, which provides a "traffic light" green/amber/red display of audio levels, with adjustable thresholds between them, and can generate Low Audio alerts in a number of ways, including audio bleeps, relay control (to switch external lights), or via an NDI signal.
I know what you are talking about. I have mixed content sometimes as well. Video clips with audio, Mics, Cams etc. and need to connected to a PA and of course the streams. I use an external mixer as well (XR 18). The mixer has several busses. I do all the audio in the mixer. vMix sends all audio to the mixer as if it would be a line/mic signal. I send the sum from the audio desk to vmix and route it to the master. The only source that goes to the master. That way I have a single touchpoint for the audio mixing (I use automatic ducking, automix, fx, etc). I monitor the audio from the mixer. So far so good.
