2 Pages<12
MartLeib
#21 Posted : Tuesday, September 25, 2018 2:19:06 AM(UTC)
MartLeib
Estonia
Vuurmannetje wrote:
...That is, if I can fit it in between my GPU and all haha...
https://www.thermaltake....6_Riser_Cable/design.htm works without any problems.
Vuurmannetje
#22 Posted : Tuesday, September 25, 2018 1:09:37 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Thanks for the tip!
Ill look into it later, mostly because Id need to find a proper way to attach it in the case. Plenty of space luckily.
So today I got the proper black screws in and finished off my main patch panel. I also prepped all audio cables for soldering, but I'm doing that tomorrow.
Last week I did run a hardware stability test with Vmix, including taking a look at keyframe latency. Attaching a pic of that too!
EDIT: Forum doesnt play nice uploading. So here are some external links:
So whats happening on the test:
Sync test video on Desktop > NDI input on BEAST > NDI monitor on Desktop
https://imgur.com/a/oMUIFmB
https://imgur.com/a/5WweVUg
Vuurmannetje
#23 Posted : Sunday, October 14, 2018 10:46:07 PM(UTC)
Vuurmannetje
So today I got to wait one more day to get the flightcase and finish up. 2 weeks of waiting was haaard
But, today Im doing whatever I can then to finish up, like making the Xkeys pretty etc. Rest is all ready for screws anyways
Vuurmannetje
#24 Posted : Tuesday, October 16, 2018 7:25:31 AM(UTC)
Vuurmannetje
Picked up my case today...
Psyched!
Tomorrow full day of install.
44049107_2073784222652940_5892474549181612032_o.jpg (108kb) downloaded 6 time(s). 44100039_2074080975956598_774668648290713600_o.jpg (111kb) downloaded 8 time(s).
Vuurmannetje
#25 Posted : Thursday, October 18, 2018 2:41:03 AM(UTC)
Vuurmannetje
Notorious double posting!
Long post this time.
So, I got the flightcase in the other day.
And started my day by installing it all after some fresh coffee
Then this happened!
DSC_0225.JPG (262kb) downloaded 5 time(s). DSC_0227.JPG (222kb) downloaded 10 time(s). DSC_0226.JPG (266kb) downloaded 10 time(s).
So today I set it up at its first production. Just a simple presentation and some video cues. Friday Im prepping a 100% online production, then next week ill make some promo pictures.
Vuurmannetje
#26 Posted : Tuesday, October 23, 2018 8:33:58 AM(UTC)
Vuurmannetje
So today I pretty much finished up the mobile studio.
Its been a fun week, and running the production on Wednesday/Thursday (pretty much put up one presentation in a larger production) revealed some starting diseases. For one, I shouldve double checked the BMD Quad 2's connection chart on 8 way mode, because the order is definitly not 1-8.
Only issue remaining is getting the 4K SDI connector on my Extreme 12G to work, every other hardware thing works.
Yesterday I spent the day working on a preset for a special event well be running 100% online. This one uses 4 computers. 1 Main for broadcast, 2 for Video calls and another for Virtual assets and their switching. Lots of placeholders on the photo, as animations are being produced.
The TR2 holds up really nicely in this, with close to 40 NDI streams going around here. Stable at 16ms render time. Think CPU usage might go up a bit with all cameras active.
Also spent some time making sure my built in networking is fail safe and fool proof. Added in plug and play support for several Mesh Wifi access points (mostly for Newtek Sparks).
Next couple of days Ill have more time to do some actual stress testing, probably with some 4K NDI and rendering/recording to boot.
So today I started off with finishing the drawer to be neat. Note the Vmix mousepads I picked up at the IBC
After that I spent the day running stability and performance testing.
MartLeib
#27 Posted : Tuesday, October 23, 2018 4:32:33 PM(UTC)
MartLeib
Estonia
May I ask, how heavy it is? Thinking about getting it to the third floor without a lift..
Vuurmannetje
#28 Posted : Tuesday, October 23, 2018 7:30:05 PM(UTC)
Vuurmannetje
Around 350kg. In the netherlands most elevators are 500+ capacity. But gitta do a precise weighing at some point.
2 Pages<12
