Feature Requests
WebController of vMix Call remotely accessible
Hi
I've recently set up a live event with 1 Main vMix PRO hosting the call for 8 remote partecipants using vMix Basic HD The choice to use vMix on the remote caller is because I need 2 cams there I've also set up a laser presenter for the remote users in the way that any button you press is triggering a shortcut that cut between the cams but since the "monkeys" working remotely are totally useless it happened often that they were not switching between the cams and I got the wrong one in the main deck
It would be really nice to have a native subsection in the web controller of vMix host of the remote shortcuts of vMix caller
I was then wondering if there was a way to handmade a solution in situation where you do not have time nor any control over firewall of remote locations I've then figured out to set up a ssh connection opened from the remote caller to a server hosted on cloud that tunnels local 8088 port to a remote 8091-8098 for all caller Next I made a dumb html page that embed all 8 WebController in a single page
<html><head><meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> <title>Multi Web Controller</title> </head> <frameset rows="50%,50%"> <frameset cols="25%,25%,25%,25%"> <frame src="http://webcontroller.domain.ext:8091/"> <frame src="http://webcontroller.domain.ext:8092/"> <frame src="http://webcontroller.domain.ext:8093/"> <frame src="http://webcontroller.domain.ext:8094/"> </frameset> <frameset cols="25%,25%,25%,25%"> <frame src="http://webcontroller.domain.ext:8095/"> <frame src="http://webcontroller.domain.ext:8096/"> <frame src="http://webcontroller.domain.ext:8097/"> <frame src="http://webcontroller.domain.ext:8098/"> </frameset> </frameset> </html>
Obviously SSL could be set up for better security but since I locked down the access to the hosted server allowing only callers public IPs to open ssh sessions and my public IP to access 8091-8098 ports I was not really worried about it
It works like a charm and allows to manage remote vMix caller shortcut easily from a tablet
I hope it can be useful to someone (or maybe there's an embedded function that does it natively and I'm a idiot :D)
Regards Marco
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Feature Requests
