DiscipleDOC
#1 Posted : Saturday, September 15, 2018 12:14:09 PM(UTC)
DiscipleDOC
How do I receive phone calls through vMix? I would like to have people to call into my live broadcast and I am using vMix HD.
Thanks in advance.
#2 Posted : Saturday, September 15, 2018 12:24:11 PM(UTC)
Please search the forum before asking. This question has been asked and answered many times already
You'd already have had many solutions to try by now if you had made a little effort to search
Guillaume
TuesdaysLive
#3 Posted : Saturday, September 15, 2018 12:55:37 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
Actual Phone calls are outside the scope of vMix and the vMix Call capability.
You would need to use a third party capability to do that.
mjgraves
#4 Posted : Saturday, September 15, 2018 2:27:57 PM(UTC)
mjgraves
I do this literally every week, and have done for about seven years.
First - you said "phone calls" so I presume that means you want your guests to be able to dial a normal phone number and reach you, with no other technical complexity. Ubiquitous, easy access.
My situation is a little different, since I allow anyone to join the show by telephone. Not just a single, planned guest.
I use a SIP soft phone installed on my vMix host. It connects to a conference service (http://www.zipdx.info.) The audio to/from the SIP soft phone is dealt with using the same mix-minus technique that people have long used to receive Skype into vMix.
My "guests" dial into the conference service and enter a conference code. They are then connected to my show.
To keep noise to a minimum, I set the conference service to keep everyone muted at first. So they are listen-only. They can unmute themselves by pressing *6 on the telephone keypad if they want to speak.
The conference service has access numbers in about 60 countries, which makes it easier to have guests connect from far-off locations. It can also call out to them, which is sometimes cheaper and more convenient.
The conference dashboard has a great set of controls for managing the participants connected by telephone. I think of it as the stage manager & green room.
If you only need a way to connect to a single guest by telephone, you may not need the conference service. Any SIP-based phone service (there are dozens, like Vonage, OnSIP, etc.) That would give you a phone number that you can bring into your vMix system.
As a practical matter, given typical billing models, it can be both cheaper and more scalable to use ZipDX.
Aside #1 - back in 2008 I interviewed the founder and CEO of ZipDX, which is how we met. He eventually sponsored our show, providing the ZipDX platform for our use which continues to this day.
Aside #2 - In 2013 ZipDX ended up hiring me.
Aside #3 - ZipDX supports wideband telephony (aka HDVoice,) which delivers far better audio quality. However, this post is already long enough.
thanks 2 users thanked mjgraves for this useful post.
stevespaw on 9/15/2018(UTC), Bamboo on 3/22/2020(UTC)
mjgraves
#5 Posted : Saturday, September 15, 2018 2:52:55 PM(UTC)
mjgraves
The old skool approach is to use a land-line and a telephone hybrid, like one of these. That presumes that you have rest of the Audio I/O to work it into your production.
michaelrb
#6 Posted : Thursday, September 27, 2018 11:13:28 AM(UTC)
michaelrb
Rank:: Advanced Member
If you use a mixing board then a BlueDriver M3 from JK Audio might do the trick. It plugs into a mic input on your mixing board and pares with your phone via bluetooth. It;s a bit costly....in the $300 range .....I think. You can also use SKYPE and just import the audio. Need virtual cables to do this, but it works fine.
