Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
This crash happens after loading a certain large profile and clicking on Record settings(gear) button. I can load any other profile or no profile and the record settings will open without crashing vmix.
Log Name: Application Source: Application Error Date: 9/14/2018 1:33:20 AM Event ID: 1000 Task Category: (100) Level: Error Keywords: Classic User: N/A Computer: DESKTOP-FTUJJUI Description: Faulting application name: VMIX64.EXE, version: 21.0.0.56, time stamp: 0x5b90b987 Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc0000005 Fault offset: 0x00000000d6ba6d20 Faulting process id: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report Id: %13 Faulting package full name: %14 Faulting package-relative application ID: %15 Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID> <Level>2</Level> <Task>100</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2018-09-14T06:33:20.227870200Z" /> <EventRecordID>12589</EventRecordID> <Channel>Application</Channel> <Computer>DESKTOP-FTUJJUI</Computer> <Security /> </System> <EventData> <Data>VMIX64.EXE</Data> <Data>21.0.0.56</Data> <Data>5b90b987</Data> <Data>unknown</Data> <Data>0.0.0.0</Data> <Data>00000000</Data> <Data>c0000005</Data> <Data>00000000d6ba6d20</Data> </EventData> </Event>
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
It sounds like one of the input devices is corrupting memory, or the system memory is faulty.
To test this:
1. First run the Windows Memory Diagnostic and see if there are any errors. 2. If no errors, Add the inputs one by one until the culprit is found.
Martin vMix
One other small possibility, if you have had AJA drivers installed in the past, uninstall these and install the latest drivers.
There is an AJA codec that crashes when memory usage exceeds 4GB.
admin wrote:One other small possibility, if you have had AJA drivers installed in the past, uninstall these and install the latest drivers.
There is an AJA codec that crashes when memory usage exceeds 4GB. I have never installed AJA drivers on this system. I can't seem to find which input is the issue. I have removed a bunch of different ones and the issue goes away after removing a bunch, but not one specific input. Is there some extra debugging I can enable?
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
kevev wrote:I can't seem to find which input is the issue. I have removed a bunch of different ones and the issue goes away after removing a bunch, but not one specific input. Small steps. Try removing the inputs ONE AT A TIME to determine the culprit. Removing them in a "bunch" will not help you find your problem.
TuesdaysLive wrote:kevev wrote:I can't seem to find which input is the issue. I have removed a bunch of different ones and the issue goes away after removing a bunch, but not one specific input. Small steps. Try removing the inputs ONE AT A TIME to determine the culprit. Removing them in a "bunch" will not help you find your problem. Understood. I have a bunch of image sequences that take forever to load. I ran out of time last night as I stayed up till 3:30am trying to pinpoint the issue. What's weird is in my testing I removed different inputs that ended up fixing the issue between my test runs. I am starting to think the issue with quantity rather than one specific input. I may just rebuild the preset as our production is tomorrow and we are running out of time. It would be nice if vMix actually logged errrors before crashing. It crashes right after the Record settings finally open for a second.
I figured out that it is not my inputs causing the crash. The crash happens when I have 16 or more inputs. Anyone have a solution? I have reinstalled vMix. I have removed temp files. I have re-installed .net .
Can you list here all the codecs that appear in the Recording Settings -> AVI tab Codec dropdown box? One of those codecs is causing the crash, so we need to work out which one it is to uninstall it.
Martin vMix
admin wrote:Hi,
Martin vMix  The MagicYUV codec was installed by the Decklink Quad 2 driver.
Quote:The MagicYUV codec was installed by the Decklink Quad 2 driver. I don't think so, it was most likely installed by vMix. However, although I feel like there is nothing wrong with your codecs, I'll let Martin give his experienced and valuable thoughts about this... Only thing I can suggest is not to use the C: drive for recording as a general best practice advice... but not sure if it's related with your issue Guillaume
Hi, That codec list looks ok, so there might be a hidden codec causing issues. To find it: 1. Install Autoruns: https://docs.microsoft.c...rnals/downloads/autoruns2. Run the program and go to the Codecs tab 3. Take a screenshot and post it here if possible. Thanks, Martin vMix
admin wrote:Hi, That codec list looks ok, so there might be a hidden codec causing issues. To find it: 1. Install Autoruns: https://docs.microsoft.c...rnals/downloads/autoruns2. Run the program and go to the Codecs tab 3. Take a screenshot and post it here if possible. Thanks, Martin vMix
Were the screenshots helpful? I need to resolve this soon.
You can try unticking the 7 items in the top category, rebooting and seeing if that helps. It will temporarily disable all the AVI 64bit codecs.
They don't look out of the ordinary, but maybe one of them is causing issues unique to your system as this is not something we have ever encountered before to be honest.
Martin vMix
Also just to confirm you ran the full Windows Memory Diagnostic and didn't find any errors?
admin wrote:Also just to confirm you ran the full Windows Memory Diagnostic and didn't find any errors?
I did not see any errors reported after the memory test. I found out which codec was causing the crash. After disabling "Blackmagic MJPEG Decompressor" vMix no-longer crashes. I am going to attempt an upgrade from Blackmagic Design Desktop Video 10.11.1.0 to 10.11.2.0 . Maybe there is a newer driver included. Edit: I have updated to 10.11.2.0 and the same crash happens. After disabling that specific codec all is good. I hope it is not necessary for vMix. Here is the info for the disabled codec after the update:
 2 users thanked kevev for this useful post.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
