Feature Requests
Click and Drag Multiple Inputs
A simple request, really.
I'd like to be able to click and drag more than one input at a time. The current software only allows one input to be selected and moved. Any work which requires the movement of multiple inputs (to either change the order or move to a different tab) is laborious when needing to deal with a lot of inputs.
[A clever image would be here if I knew how to embed said image]
Thanks, vMixFolks!
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
+1 Here is how to show an image There is an image button in the menu above the dialog box and I just pressed that. Then inside what pops up you put the URL LINK. Added my Insta Profile Image as an example.  Code:[img]https://scontent-sjc3-1.cdninstagram.com/vp/fee5558ee3798648eef9fcd6aa6b218e/5C35D64C/t51.2885-19/s150x150/37016268_299881080759673_4650858740096958464_n.jpg[/img]
Hope that helps. Rich Shumaker
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
 1 user thanked Video Dave for this useful post.
Feature Requests
