Virtual inputs not being saved
Hello, I am using the Trial, v 10.0.0.59 And I need to be able to save my virtual inputs, otherwise setup time for us will be way too long. We have used xsplit, but want the extra (many) features of vMix.
Everything is saved between restarts and all is still there(cameras, gfx and shortcuts), but not the virtual inputs I create from my cameras. Please tell me its a limitation of the trial.
[W7pro, i7-3930K 16GB nvidia GTX650, Blackmagic duo sdi, two avermedia cards and intesity shuttle as external output.]
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
The "Virtual Input" feature is new in vMix 10 and at the moment it can't be saved to a preset.
How are you currently using the Virtual Input? In most cases you can do the same thing by using a color input and multiview.
Martin vMix
In xsplit we take one camera and make it black and white and a little "washed out" and take two other inputs on top of that. tried making it with a color input and putting a semi transparent png over the first input, but the colors from the camera steals to much attention from the overlays. I will buy your pro version anyway, but please try to make it possible to save the virtual inputs, otherwise it seems like a feature not safe for use, when using multiple operators. Great work btw.
