seb666
#1 Posted : Sunday, August 26, 2018 1:28:11 PM(UTC)
seb666
From time to time I'm cropping 4K inputs for a HD stream. Via Merge transition it's possible to zoom in and out. But I can only select 2000 ms for a transition. It would be pretty cool to have 20000 or more for some streams and some kind of damping (slow start and slowdown to the end of the transition) would be awesome.
ThomasK
#2 Posted : Thursday, September 6, 2018 9:27:43 AM(UTC)
ThomasK
Austria
Thats a real awesome use of the merge functionality - did see the use anywhere before.
In the pull-down menu located at the Wipe button, it possible to enter values greater then 2000ms, but they dont get active if they are greater then 9999ms and revert back to default.
So anything greater then 2000ms is already possible.
Best,
Thomas
