adimw
#1 Posted : Thursday, August 30, 2018 7:43:45 PM(UTC)
adimw
Howdy, Adam from New Zealand here.
We record a weekly company video update which is published on our Intranet (Sharepoint)
We ingest powerpoints and other video. This is also shown on two TV's as the 'show' is produced live. I'd probably have stuck with Wirecast but the program doesn't have good options for audio mixing (A&B Bus). I've since found my way to vMix and am liking it a lot.
I am running Windows 10 Enterprise 2016 LTSB (Build 14393), vMix Pro
PC hardware:
DISPLAY: Dell 24 Touch Monitor: P2418HT
CPU: Intel i7 8700
RAM: 2* 8GB GSkill RAM
GFX: NVidia GeForce GTX 1060 6GB
MOBO: ASRock Z370 Taichi ATX Motherboard
HDD: Samsung 860 EVO 500GB 2.5" SATA (media/capture)
HDD: Samsung 960 EVO 250GB M.2 (boot/windows)
PSU: EVGA SuperNOVA 650W 80+ Gold
CAPTURE: Magewell Pro Capture Quad SDI Card (4 Channel)
CAPTURE: Magewell Pro Capture Quad HDMI Card (4 Channel)
Attached devices:
Elgato Stream Deck (via USB)
Zoom UAC-8 ASIO (via USB) for 4x LAV wireless mics
Canon XA35 (via SDI) primary camera
Canon HF G25 (via HDMI) secondary camera
Logitech PTZ Pro 2 (via USB) 'audience' and PTZ special shots
NUC (via HDMI) Ingest for video/powerpoints
thanks 2 users thanked adimw for this useful post.
ThomasK on 9/2/2018(UTC), mjgraves on 9/6/2018(UTC)
ThomasK
#2 Posted : Sunday, September 2, 2018 10:27:59 AM(UTC)
ThomasK
Austria
Could you outline which exact MICs you are using? We are searching for a wireless upgrade.
Thx
StephenH
#3 Posted : Thursday, September 6, 2018 6:34:59 AM(UTC)
StephenH
Hi Adam,
Do you use your Stream deck to move your Logitech PTZ pro Camera?
If not could you tell me how you achieve ptz movement please as i have one and can only move via remote.
Thanks.
adimw
#4 Posted : Friday, September 14, 2018 3:03:48 AM(UTC)
adimw
Thx
Howdy, they are older Azden units. Probably bought them 3-4 years ago. Have been good, but didn't use the LAVs that came with them, I went straight to Sennheisers.
https://www.rubbermonkey...R-UHF-on-camera-receiver
thanks 1 user thanked adimw for this useful post.
ThomasK on 9/14/2018(UTC)
adimw
#5 Posted : Friday, September 14, 2018 3:04:58 AM(UTC)
adimw
StephenH wrote:
Hi Adam,
Thanks.
Just via remote currently; though there is an app that allows remote control as my video conferencing rooms use the same camera model and are controlled from the room PC.
