Thanks: 8 times Was thanked: 45 time(s) in 22 post(s)
I just started using Decklink SDI card in PAL SD 720x576 50i mode, using vMix 10, Windows 7, BM 9.7.5 driver.
Sometimes SDI input develops around one second delay. After severe testing I was not able to find any regularity or connection to any other factors - sometimes it happens after one minute, sometimes it does not happen for 3 hours. After resetting the input, problem disappears.
Not sure if this is related to vMix or BM driver. Has anyone had a similar problem or has a solution?
BR, Dundurs
