Hardware Compatibility
Akai APC 40 MKII - Activators for Streams
Hi everybody,
I just bought the Akai APC 40 MKII as a controller and I love it. It makes life so much easier in combination with vMix. However, there are some issues that I can´t get solved and as I also don´t know if it works with scripting I thought best is to ask here before.
The setup: I have three different streams defined: Facebook, YouTube and Twitch. They are set up as Stream 1, Stream 2 and Stream 3, so when assigning a Shortcut to the button which should start the stream I have to put in the numbers 0, 1 and 2 for the streams 1, 2 and 3. It works, I have three buttons that start/stop three different streams.
But on the activators the onliest action is "Stream active". So when I try to have the buttons light on, I can´t make any difference between the streams. As soon as any of the three streams are online, all three buttons are lit. How can I make this a little bit more smooth? I like to have the buttons lit on only when the corresponding stream is online and not if ANY of the streams is online.
All the best, Julian!
