I am setting up a newsdesk and would like an LED light panel to turn on when I fade in a camera. Is there any way to do this? I can find a way to light up tally lights but not entire LED panels. Thanks
Joined: 3/15/2018(UTC) Posts: 82  Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Thanks for this. That x-keys does what I want but the power relay device in that Youtube video is only for US sockets. I can't find a UK one, unless someone knows of one?
From what I gataher, Arduino can only control tally lights, not other external mains devices, right?
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
sdonn wrote:From what I gather, Arduino can only control tally lights, not other external mains devices, right? It can only control low-power LED tally light directly, but if the Arduino output was used to control a relay with a higher power rating, or an electronic triac switch, then it could control much higher power loads - anything's possible.
But the functionality is limited to tally lights, not triggering lights through shortcuts no? FOr example I want a light to come on when a video clip is being played and then off again at the end of the clip.
