Feature Requests
Shortcut to seek video file + Mark In/Out based on time/frames
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Basically, I'd like to see shortcut that seeks video file based on defined time or frames. In addition, since we have MarkIn and MarkOut functions already, I'd like to see possibility to define time/frame. This use case would be awesome for animated graphics. Let me demonstrate. Graphics example: First number is framecount, second is timecode. You can see, that this graphics has following parts: Animate In with bottom bar Hide bottom bar Animate Out If we had seeking and marking in/out based on time/frames, I could do the following: Shortcut 1 - Animate in with bottom barOverlayInput1Out MarkReset SeekVideo to frame 0 (or Restart) MarkIn at frame 0 MarkOut at frame 80 OverlayInput1In Shortcut 2 - Hide bottom barMarkReset SeekVideo to frame 80 MarkIn at frame 80 MarkOut at frame 150 Play Shortcut 3 - Animate OutMarkReset SeekVideo to frame 150 MarkIn at frame 150 MarkResetOut Play In this example SeekVideo is not really used that much thanks to MarkIn/Out But if we take Golf for example, sadly, I do not have access to this graphics at this time, but we have animated scorebug which has bottom parts alike. For birdie For par For bogey etc. Since we have to show different people, I could use SeekVideo to jump between different terms very fast, and in a animated form.
Feature Requests
