Joined: 8/22/2018(UTC) Posts: 5 Location: South Africa
How can I do a squeeze back where I have the output move to the top right corner and still be able to switch cameras while putting... lets say some advertising around the bottom and left side of the output? See link as example:
you realy should have searched the forum as the exact same thing has been addressed before with solutions !
hint: "Animated PiP"
Thanks doggy, I did see some of those, but they seem to use one camera angle to "Squeeze back" not the output so you can keep switching between cameras. Please advise.
kind of tricky to change the ouput of an output. my initial inclination would be using a second computer, one that creates the usual output mixes and the second one to add the Squeeze back to it and does the streaming
or using shortcuts to manipulate a multiview as a so called output , but more restricted/complicated i would guess
@ Freddie Vorster
As doggy indicated, it can be tricky, but it is possible if you use a MultiView Input, an external Output (vMix 4K or Pro) set to Preview and an Overlay channel. Set-up: - For simplicity sake, lets say 3 camera inputs with default click to send to Preview. - Multiview with advert screen underneath and Cam 1 squeezed back as desired (UpStreamKey). - Set desired Overlay channel to exact same squeeze back as in Multiview (DownStreamKey). - Set desired Output (2,3 or 4) to Preview and enable NDI. - Add NDI Input of said Output back into vMix. - When Cam 1 is LIVE, Merge from Cam 1 to Multiview for squeeze back effect. - With Cam 1 now in preview, Overlay new NDI Input (Output of Preview as DSK) - Send cameras 1, 2, and 3 to Preview at will (with click or Shortcut) - When advert is complete, make sure Cam 1 is in preview. - Remove Overlay (DSK) revealing original Multiview (USK). - Merge back to Cam 1. - Resume regular switching.
IceStream wrote: it is possible if you use a MultiView Input, an external Output (vMix 4K or Pro) set to Preview and an Overlay channel.
true as was my thoughts too but i always try initially with less then 4K or pro versions first ;-)
