NDI
NDI Multicast for Venue displays
Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Now that NDI has multicast functionality - has anyone used NDI out (with multicast enabled in NDI Access Manager) of Vmix for display to multiple screens around a venue?
If vMix had an option to output NDI-HX - What would it take to multicast wirelessly to multiple displays in a venue over wireless with NDI-HX? What would the ideal set up look like, and what are the pitfalls one would be setting themselves up for?
lael wrote:If vMix had an option to output NDI-HX - What would it take to multicast wirelessly to multiple displays in a venue over wireless with NDI-HX? What would the ideal set up look like, and what are the pitfalls one would be setting themselves up for?
NDI/HX is for hardware devices only. The question is moot.
Humour me - say we run an HDMI out from vMix into a Connect Spark?
If you're considering NDI-HX, just encode to an RTMP stream and reflect it off an NGINX instance. Your own local stream to clients on your LAN. Minimal workload for the NGINX server, it could be a raspberry Pi.
You could use a hardware encoder, but that would likely only serve a few client streams.
There will be some latency, but NDI-HX has latency anyway.
I've considered this sort of thing for on-campus digital signage.
If you have wired Ethernet running near the displays, you don't have to use NDI-HX, normal NDI® (NDI for compute) will work. All of the switches on the NDI network do need to support IGMP Snooping to use multicast.
If you are looking to do this wireless (shudder), then some other technology is probably an better way to go.
Kane Peterson NewTek
NDI over Gigabit LAN would be our ideal. Unfortunately there are no wired ethernet ports in the venues we will be in, or they are on networks that we won't have access to test and configure before we arrive in order to guarantee success. Hence looking for an alternative that is definitely not ideal. Wireless - because we bump in the morning, and bump out that afternoon and need to reduce set up time. Running cable takes time and needs to be taped down / secured for WHS reasons and would be some quite long runs. At the moment the tentative plan is a point to point or point to multipoint set up from a central distribution pole to 4 displays using something like a https://www.ubnt.com/airmax/liteap-ac/ as the base and https://www.ubnt.com/airmax/nanostation-ac/ or https://www.ubnt.com/airmax/nanobeam-ac-gen2/ as the receivers (probably a 1-2 setup). Or go straight for a 1-1 ptp nanobeam to nanobeam setup. We have some concerns around using something rather overpowered for basketball size court(s) locations, and of course potential interference between each link. Kane - if you have advice on alternative options I'd be happy to have some leads to chase down.
YOu did not indicate the most important thing to consider: can you bear latency or do you need absolute realtime?
First, this topic was discussed so many times already on the forum, don't ask for alternatives, go read them... It's your need, not our duty...
Second, planning on using NDI on a network you do not own and control is pure madness. You might get lucky from time to time but very unlikely
Third, why NDI? Is there any particular reason that makes it mandatory? So far, NDI is not ideal for distribution due to its technical requirements that makes it the most expensive protocol to use.
Fourth, if you're to use NDI|HX, why on Earth would you pay for an encoder that multicasts H.264 when FFMPEG/VLC/etc do the same for free with more control over image quality, encoding parameters and so on? I understand you find it "cool" and trendy but in terms of IP Video the world has not waited for NDI|HX. I think I multicast H.264 for at least 7 or maybe 8 years...
Guillaume
DWAM wrote: Second, planning on using NDI on a network you do not own and control is pure madness. You might get lucky from time to time but very unlikely.
+100. This is wisdom. Third, why NDI? Is there any particular reason that makes it mandatory? So far, NDI is not ideal for distribution due to its technical requirements that makes it the most expensive protocol to use. DWAM wrote: Fourth, if you're to use NDI|HX, why on Earth would you pay for an encoder that multicasts H.264 when FFMPEG/VLC/etc do the same for free with more control over image quality, encoding parameters and so on?
Again, +100. Newtek Spark is basically an tweaked RTMP encoder.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Why not just use ffmpeg to encode a multicast Transport stream right from your vMix DirectShow output? I do it all of the time.
But you still have possible issues with WiFi and Multicast being enabled on the network you don't control.
Steve
Quote:But you still have possible issues with WiFi When wireless devices are involved I usually multicast 2 streams: one 1080 with pretty high bitrate for wired devices (depending on the targets capacity) + one safe with very low requirements (i.e. 480p @ 750 Kbits) for smartphones or crappily connected computers
DWAM wrote:YOu did not indicate the most important thing to consider: can you bear latency or do you need absolute realtime?
Guillaume We'd prefer as close to realtime as possible. We set up our own network - that's actually the purpose of the post. Working out the practical limits of wifi to see what might work. NDI - only for low latency. But - you're right, if NDI-HX, then multicasting h.264 is likely a better option - what's the lowest latency you've introduced doing this?
Thanks Elvis - Looks interesting. Have you used these before and what is the latency like from end to end?
Quote:what's the lowest latency you've introduced doing this? Optimized settings 300ms Safe settings 500/1000ms With FFMPEG
Hello, Sorry for my english. (Translator) I once tested RTSP in Vmix. See video. Left input from camera, right stream RTSP, buffer 100, low latency mode. Have a latency of 300 milliseconds measured. with Video Encoder Ethernet Port and NanoStation AC NS-5ACLHad already made test with WLAN Bridge LBE-5AC-Gen2Point to point 3000 meters. Latrncy about 300 - 400 milliseconds Greeting
 1 user thanked elvis55 for this useful post.
Elvis, That's amazingly helpful - thankyou! So - to check I understand: In the Youtube video - you have camera - video encoder - ethernet - vmix with a delay of ~300ms? or - was it camera - video encoder - (wireless) - NS-5ACL - vmix with a delay of 300ms? And in the past you have used: camera - video encoder (hdmi) - ethernet - NS-5ACL - LBE-5AC-Gen2 with 300-400ms latency? or - was it camera - video encoder -(wireless) - LBE-5AC-Gen2 over 3Km! nice. Thanks! elvis55 wrote:Hello, Sorry for my english. (Translator) I once tested RTSP in Vmix. See video. Left input from camera, right stream RTSP, buffer 100, low latency mode. Have a latency of 300 milliseconds measured. with Video Encoder Ethernet Port and NanoStation AC NS-5ACLHad already made test with WLAN Bridge LBE-5AC-Gen2Point to point 3000 meters. Latrncy about 300 - 400 milliseconds Greeting
Hello
In Youtube video I have: Camera - HDMI Cable - to 2 Port HDMI Splitter - Output 1> HDMI Vmix Input 1. HDMI Splitter Output 2> with HDMI cable to Video Encoder. From Video Encoder with Ethernet Cable to NanoStation AC NS-5ACL Station, Point-to-Point to AC NS-5ACL Accespoint. From AC NS-5ACL Accespoint with Ethernet Cable to Ethernet Switch, from Ethernet Switch to Ethernet Cable in PC. Input 2 - Vmix stream RTSP, buffer 100, low latency mode.
And in the past you used: Camera - Video Encoder (HDMI) - Ethernet -LBE-5AC-Gen2 -Point to Point - LBE-5AC-Gen2 with 300-400ms latency? over 3km!
Greeting
Amazing - thankyou! elvis55 wrote:
Hello
Greeting
NDI
