Feature Requests
Streaming Status Indicators
Joined: 4/20/2017(UTC) Posts: 19 Location: Atlanta, GA
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
I'd like to place a feature request to have status indicator lights added to the top bar that would provide a visual status to each stream. (see sample image). It would be great to have buttons where the 'stream' button is now that would represent the following [all, 1,2,3]. The COG and right-arrow can stay. Here's what I have in mind. The status lights would be colored to show they are configured and match a GREEN(good), Yellow(warning), or RED(failed) status.  voiceovercity attached the following image(s):  vMix_2018-08-14_142913.png (44kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
 1 user thanked GeorgeR for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,099   Location: Fairhope, Alabama USA Thanks: 590 times Was thanked: 202 time(s) in 168 post(s)
Some discussion may be warranted...
Current vMix color protocol is Red means A-Okay (Stream, Record) or it means On (External, Playlist, etc).
While it makes sense that a "status" light indicate green for "good," it would go against the status quo.
But, +1 for the concept.
- Tom
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
Personally, being colored blind, something other than 'red' and 'green' would be preferred. It is difficult telling the difference between them.
sinc747 wrote:Some discussion may be warranted...
- Tom Agreed, It would confuse me! Perhaps Red for "ok", and yellow for "warning", and grey for "not streaming" to keep with traditional vmix colour protocol.
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
This is sort of off topic - but if you want an extra indictor you can get a blynclight ($40 usb indicator light) and run this python code in the background. It will light up green if its streaming.
# -*- coding: utf-8 -*- """ Created on Sat Feb 27 22:35:03 2021
@author: jabal """
import socket import time import blynclight sock=socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_address = ('localhost', 8099)
try: b=blynclight.BlyncLight.get_light() b.color=(0,0,200) light=True except: light=False print('no light')
while 1: time.sleep(.5) try: sock.connect(server_address) except: print('vmix not open') vmix=0 while vmix==0: try: time.sleep(.5) test=sock.sendall(b'ACTS Streaming\r\n') data = sock.recv(100) if str(data)[-6]=='1': if light: b.on=True print('streaming') else: if light: b.on=False print('not streaming') except: vmix=1
Feature Requests
