Use Stream 1 Quality and Hardware Encoding
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Quick question... I want to hardware encode 2 streams. If the 2nd stream has Use Stream 1 Quality checked, will it also use hardware encoding? The hardware encoding option for Stream 1 is greyed out unless I uncheck Use Stream 1 Quality, which is why I'm unsure what option to use to ensure both streams are hardware encoded.
Not really sure what you mean. If other streams are using Stream1 quality, there is no need to encode their streams. If Stream2 is using i different quality it has to be encoded, optionally by hardware. Note that the Nvidia Geforce cards only support two hardware encoders. Meaning if you hardware encode two different streams, you cannot hardware a third streams or a recording.
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
To clarify, yes ticking that box will also copy the Use Hardware Encoder setting, so be sure your GPU has enough encoder channels available. (2 for GeForce, no fixed limit for most mid-high end Qusdro models)
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
richardgatarski wrote:Not really sure what you mean. If other streams are using Stream1 quality, there is no need to encode their streams. If Stream2 is using i different quality it has to be encoded, optionally by hardware. Note that the Nvidia Geforce cards only support two hardware encoders. Meaning if you hardware encode two different streams, you cannot hardware a third streams or a recording. With the three streams being independent since vMix 21, are they not all encoded separately even with "Use stream 1 quality" selected?
niemi wrote:With the three streams being independent since vMix 21, are they not all encoded separately even with "Use stream 1 quality" selected? That's up to Martin to answer correctly. But my guess is that each stream to the CDN uses the same encoding stream, which is just turned on/off to the individual CDNs.
Usually streams with the same settings to multiple destinations are only encoded once and pushed to the destinations. But this does not allow independent start and stop by default. However depending how Martin wrote the independent stream feature 2 options are possible: - each destination has a dedicated command line for FFMPEG, even if encoding parameters are the same - streams sharing the same settings are encoded just once, only the destinations part of the command line is "dynamic" and can be updated on the fly
Only Martin knows I'm afraid... unless the stream logs contains clues, I never thought to check this...
Each individual stream is encoded independently regardless of settings selected. This is necessary to ensure all streams are isolated from another so an issue with one stream does not affect the others.
Thanks Richard, Guillaume and Martin for clarifying.
Independent streams is the single biggest improvement for us in vMix 21.
I just replaced a GTX 1060 with a Quadro P2000, so the resource cost for additional streams is very limited with hardware encoding enabled for both recordings and all three streams. Makes me wonder whether we didn't do this before as the price premium is almost negligible.
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Originally Posted by: niemi  Thanks Richard, Guillaume and Martin for clarifying.
I just replaced a GTX 1060 with a Quadro P2000, so the resource cost for additional streams is very limited with hardware encoding enabled for both recordings and all three streams. Makes me wonder whether we didn't do this before as the price premium is almost negligible. I am looking to replace my 1060 with a P2000 too! Are you satisfied with it? How many NVENC 1080 simultaneous records you get out of it? Thanks
Quote:How many NVENC 1080 simultaneous records you get out of it? It's not possible to say a number as it will allow as many simultaneous encodes as possible depending on the actual load of the card. So it will vary according to what's the card's used for at the same moment. Guillaume
