vMix Call
vmix call question
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
When you add a call for the first time - you get a quicklink that embeds the password.
After that initial time - how can you call up that link again??
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
Save the link. It is reusable, as long as one doesn't change or remove the vMixcall input associated with it. I do believe that someone once mentioned that there is a non-use timeout period. Thus, if it is not used after a certain amount of time (I don't remember the exact number of days) the link goes away and one would need to create a new input.
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
To confirm there currently is no timeout period on call passwords. If you had saved a preset with the call password during the beta, it will still work today.
The number is so large at 10 digits, that it is unlikely to ever need to be recycled.
Martin vMix
Thanks for the additional info and correction, Martin.
So 'Save the link' is the answer.
Joined: 7/2/2020(UTC) Posts: 7  Location: Forest Lake Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
If I have the 10-digit passwords for calls I am using, but didn't save the actual link, is there a way to re-create that link from the password info?
I didn't think to save the link when saving the passwords, and although logging in is easy with the password and sending the presenter to vmixcall.com, the link is that much easier on their end.
You have been a member since:: 7/1/2020(UTC) Posts: 104  Location: Earth Was thanked: 23 time(s) in 20 post(s)
Open call manager, scroll thru the list of events. There's your links...
Or, go to vmixcall website, enter name/password and connect to call. copy url from browser to give to caller.
Joined: 3/3/2019(UTC) Posts: 9   Location: Brasília Thanks: 1 times
Originally Posted by: admin  To confirm there currently is no timeout period on call passwords. If you had saved a preset with the call password during the beta, it will still work today.
Martin vMix Hi Martin, Is it possible to use vmix call URL under a frame? I tried but it does not work. Thank you! Guilherme
vMix Call
vmix call question
