Feature Requests
Converting incoming data and using as triggers
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I'm getting scoreboard data in minutes and seconds. If the seconds are 2 digits, then everything is fine, but with only one digit it doesn't show it as 09 it only shows it as 9. there fore it would look like 13:9 instead of 13:09.
The ability to convert such data (or any incoming data into a specific output) would be much appreciated.
Another example: I also get the period..but ony get numbers from 1-4. If I could convert 1 to 1st and 2 to 2nd and so one, everythign would be solved.
+ using incoming true/false commands as triggers
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
that's a lot of specific formatting ;-)
almost easyer if the sourceprovider prepared it as such before sending ;-)
I just came accross that idea because I saw the exact same function in NewBlue titler and I guess a simple "if variable 1 = X then X will be converted to xyz" would be that complicated, but what do i know, I'm no coder.
It's not about solving this specific problem for me, it's more about being more flexible with different source data.
And the trigger part would be really helpful in automatic a lot processes.
Feature Requests
