Helicool
#1 Posted : Tuesday, July 24, 2018 1:17:27 PM(UTC)
Helicool
With apologies, I'm new to v-mix, and I have what I believe is a simple issue I can't seem to solve.
The playpack machine is is a new Asus ROG with a 1050 card and SSD drive / WIN10, the machine only has a fresh install of V-Mix on it - I've followed the optimisation details on the website. For a very simple application I need to playback (2) 1 minute videos in MP4 format - each video is about 10MB in size.
When I play back each file the first time, all is fine - I play file A and then cut to file B - all is good.
When I cut BACK to file A again, about half way through the 1 minute file, the VIDEO portion of playback slows down in the both the preview and output pane, while the audio continues at the correct speed.
If I RELOAD the media file, it will playback properly THE FIRST TIME - I must reload it every time for it to playback correctly.
I'd love to hear any ideas you may have - I'm scratching my head!
TIA,
RM
#2 Posted : Tuesday, July 24, 2018 2:54:10 PM(UTC)
Tell us about these videos codec and metadata
Use mediainfo to retrieve all information
Guillaume
