Hello, is there the possibility that in a single virtual set I can have 3 talents and three different backgrounds? the idea is to do as in tricaster, that each virtual set has the possibility of being used multiangulo with 2 or 3 simultaneous cameras. in vmix I have not found it, it could only be done with a camera, thanks
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
@ elpejo
To be fair, I am not all that familiar with how Tricaster handles their virtual sets, but with vMix, you need a set for every camera position you want to use. That is, each set has a single camera position with different field of views or zoom levels (I find it somewhat misleading when called camera "angle" as it's always the same position, just a different zoom). So if I have understood you correctly, to accommodate 3 different camera positions, you would require 3 different positional views of the same set design (i.e. 3 different sets) one for each camera.
