Reynaldo
#1 Posted : Friday, July 20, 2018 6:24:15 PM(UTC)
Reynaldo
I am setting up a VMix preset and am having problems with an MPEG4 file as an input. It has to bottom 2/3rds cut off and with a double image. Other files (AVI, for example) seem to work fine as well as a couple other inputs (webcam, Sony FS5 input via Blackmagic Intensity Pro card. It seems to be only the MPEG 4 files encoded at 1920x1080, 29.97p.
Any help would be appreciated.
J
Reynaldo attached the following image(s):
VMIX MP4 Issue.jpg (592kb) downloaded 20 time(s).
mavik
#2 Posted : Saturday, July 21, 2018 6:08:17 AM(UTC)
mavik
There is blocking visible. I bet it's the file itself. You might want to load it into VLC and restream. Or load it into an NLE and render again. I personally use a tool named videoredo which offers a quick fix function. In most cases I could heal files with it.
