Thanks: 27 times Was thanked: 8 time(s) in 8 post(s)
Hello Guys,
i try to use the search but i could not find my case.
I want to show in the halftime break of our basketball games all the played replays from the first half and at the end of game all played replays from the whole game.
Is there a chance to make just one shortcut for the halftime highlights and one shortcut for the whole game? Both shortcuts must select the events and play them automatically and starting music. Possible?
Thank you ;-)
If you create a Shortcut with ReplayPlayAllEventsToOutput It will play the entire list of recorded replay segments up to that point. Check out the vMix Users Guide under Shortcut Function Reference https://www.vmix.com/help21/
 1 user thanked SportsNetUSA.net for this useful post.
Thank you!
That was the shortcut, i was looking for.
But there is no shortcut function for starting the music. Is that correct?
Sorry, I didn't read your post thoroughly. Yes you can start the music bed too.
One way would be to make another Shortcut to play your music file as an Overlay, then add it to the ReplayPlayAllEventsToOutput Shortcut under Advanced. You'll need to have the Input for audio file on (Green) prior to using that Shortcut, or make one that turns the audio on (which can be combined under Advanced)
I'm sure there are other, more sophisticated ways of doing it using Triggers.
