AlanZ
#1 Posted : 7 years ago
AlanZ
Today I did a test with a site where we are demonstrating via vMixCall on Saturday morning.
We tried having them connect using Chrome, and the participant could not connect to my vMixCall instance.
In my vMix input, I could see that he was trying to connect, but the connection kept failing.
The participant's venue is at a school, so they likely have some firewall restrictions in place that's beating up vMixCall over a web browser.
He saw the typical UDP message.
So unless we can get this resolved, we will use Zoom... which connected with no issue.
My question is about something we did not try... would using a vMix Basic HD instance on the participant computer with a vmix call input have any better chance of getting through the firewall to my vmix call session?
AlanZ
#2 Posted : 7 years ago
AlanZ
Anyone?
AlanZ
#3 Posted : 7 years ago
AlanZ
Well, I tried connecting vMix to vMix. He could see my chat messages, but no video or audio was sent in either direction.
We wound up using Zoom, with no issues.
kjones9999
#4 Posted : 7 years ago
kjones9999
There would be no difference. I work at a school and can assure you that UDP is the issue -- and prob ports too -- this may help -
vMix Call is able to establish connections automatically through most firewalls, however in some cases your network administrator may need to allow access for the best results.
Firewall Requirements
TURN/STUN: Port 10349 UDP/TCP
Video/Audio Streams: Dynamic Port Allocation UDP - 49152-65535
Minimum Requirements
vMix Call can establish a connection with only TCP access to remote port 10349.
However, audio and video will need to be routed via one of our remote servers, so call quality may be reduced as a result.
AlanZ
#5 Posted : 7 years ago
AlanZ
Yes, I read the docs about UDP, but I wasn't sure it applied to direct vMix to vMix sessions. Chat messages went through during my test, but did not during the browser based test, so there are some differences.
fortunately Zoom was able to get through.
mjgraves
#6 Posted : 7 years ago
mjgraves
If it's possible to establish the connection using only STUN, the connection will be direct between you vMix host and the browser hosting the vMix Call. STUN is a mechanism to establish the IP addresses of the ends and setup NAT traversal.
If network component blocks the STUN effort then webRTC uses TURN. That causes the media to flow to/from a TURN server, not directly between the end-points. TURN makes the connection possible in constrained circumstances, but since it adds a server in the middle it always adds latency and variability.
AlanZ
#7 Posted : 7 years ago
AlanZ
Well, in any event, we were not in a position to request any changes on the venue side, and fortunately Zoom was able to get through their restrictions.
