Joined: 5/15/2011(UTC) Posts: 36  Location: south Korea Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
hi. I am julian lee, this is South Korea. HD video processing and want to use your solution. I want to install the vMix, win7-64bit is installed on the why not? In win7 S/W compatibility problems? Right-click the installer to vmix -> administrator running -> no replay (win7) Please advise.
my note-book : i5 540(2.53GHz) RAM : 4GB OS : WIN7 HOME 64bit DELL NOTE-BOOK
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
I Sorry en Español Actualiza bien tu sistema Operativo update : IMPORTANT: .NET Framework 3.5 SP1 is required to run this software. Click Here to download the framework from Microsoft's web site. LINK <<Uso WIN 7 = 64 ULTIMATE 4 GIGAS RAM DELL STASION XPS TODO BIEN !!
Hi Julian Lee,
Please post the full error message that you receive.
Thanks,
Martin vMix
Thanks,ELCHPIN, Martin. Recently in win7 is upgraded to Explorer 9. Control Panel, Microsoft.NET Framework 4 Client Profile has this installation. .Net Framework 4 to artificially erased, NET-F 3.5 installed, the installation is not supported. In conclusion, under NET Framework 4, vMix is not installed? vMix Installation: a special error-messages. No no reply.
Low-spec my other PC (XP), well after the installation.
My laptop is Vidblaster, wirecast, xsplit, installation was fine with no problems. VMix solution to some of the test, but it is fairly smart. In particular, computer resource problem, it is Best. We have Full HD I want to test, test computers is worried because win7-64bit. CPU: 2600k RAM: 8GB (2200MHz) VGA: GTX470 SSD: 128GB
Questions: FULL HD (1920x1080) did not support the codec for recording? Users need to buy a codec?
hi, Martin. I did was vMix Beta 5 test. (1080HD) Very good video processing.
Settings: External Video(1080) Input (Intensity Pro (1)) Video + Audio -> PGM -> external output (Intensity Pro (2)) HDMI -> TV monitors.
TV monitor output phenomenon: the video is very good. Audio is very slow (2-3 sec). I got the settings wrong? Or intensity Pro driver configuration problem? About these issues, I go check out the forums, I do not know. Please reply.
Computer spec : i7-870 / RAM 4G(1333MHz) Intensity pro 3 SSD: 128G win7 - 64bit .net Framework 4.0
