NDI
ndi closes titler live 3
You have been a member since:: 8/21/2017(UTC) Posts: 319 Location: Uk
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
Kaaane *shouts from mountain top*
just wondering if there's any ideas, but I recently upgraded titler live 3 and now if I enable ndi as an output it crashes it/ suddenly disappears. Or if I'm opening a project that has ndi already set to output it doesn't get past loading before disappearing? thank you
Barney Box Lane wrote:Kaaane *shouts from mountain top*
just wondering if there's any ideas, but I recently upgraded titler live 3 and now if I enable ndi as an output it crashes it/ suddenly disappears. Or if I'm opening a project that has ndi already set to output it doesn't get past loading before disappearing? thank you Have you contacted NewBlueFX? Sounds like they are the ones to talk too. I've got Titler Live build 3.0 180525 running on my laptop in NDI mode, so it might be a driver or some other installed application causing the crash. Kane Peterson NewTek
cool thank you, yeah I'm speaking to them about it too, when you say about driver I did also do a Gforce graphics update at the same time, thank you for the quick response
it was a title causing everything to shut down when ndi came on, unfortunately I did a clean install and I've now only got 2 playlists so got a lot of shuffling to do before the next, but the issue was titler 3 side
NDI
