Multiple data sources issue
If i have multiple data sources, i can not see the all data sources list because it just can't. There is no scrollbar to view more data sources...
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
I already adressed this issue to Martin, he told me to make the window bigger.
Rinsky wrote:I already adressed this issue to Martin, he told me to make the window bigger. It's funny, if i have 20 data sources, i think i don't have so big window to resize to show all data sources :(
use more displays to expand the window :D
Joined: 8/2/2015(UTC) Posts: 364 Location: Sydney Thanks: 283 times Was thanked: 76 time(s) in 62 post(s)
I have mention this previously in feature requests. I have a lot data sources and if on small monitor I cant scroll, so some can be hidden and you can only expand the window so far. I would suggest simple add scrollbar or change the layout so can have unlimited number of datasource tabs.
corporatejames wrote:I have mention this previously in feature requests. I have a lot data sources and if on small monitor I cant scroll, so some can be hidden and you can only expand the window so far. I would suggest simple add scrollbar or change the layout so can have unlimited number of datasource tabs. Yes, i agree with you
