NDI
Desktop Capture direct from App (Videoplayer included in Apps)
Hi, we use https://www.microsoft.co...gn-language/9wzdncrdj1g3 every week min. 2nd times in our vMix Live-Production and streaming. Former we use all Video-Sources from DVD or any Video-File, makes a lot of work. Now it's published a App included all Bible-Video what we need often. We can use it over NDI/Desktop Capture, but the App-Functions and Tools comes within, not the best way. Any Applications are direct working with vMix, for example Skype - the Skype Video-Source can be direct used. Is it posible to get only the Video-Frame from the Windows-App "JW Library Sign Language" in vMix as Source? thx
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
gbischmi wrote:Hi, we use https://www.microsoft.co...gn-language/9wzdncrdj1g3 every week min. 2nd times in our vMix Live-Production and streaming. Former we use all Video-Sources from DVD or any Video-File, makes a lot of work. Now it's published a App included all Bible-Video what we need often. We can use it over NDI/Desktop Capture, but the App-Functions and Tools comes within, not the best way. Any Applications are direct working with vMix, for example Skype - the Skype Video-Source can be direct used. Is it posible to get only the Video-Frame from the Windows-App "JW Library Sign Language" in vMix as Source? thx if your source app works on macOS, you can use the full version of Sienna's NDI ScanConverter which has a 'crop' box feature where you can select any section of the screen to send as a dedicated NDI source. There is a demo version available: http://sienna.tv/ndi
Hi, Did you get JW Sign Language app to work with Vmix? I am currently still using Video source files but would make things easier if i could use the Sign App. Any meeting advise would be appreciated!! Thanks. Steve.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi! You should consider Streamlink which is a command-line utility that pipes video streams from various services into a video player, such as VLC. Along with NDI plugin for VLC, you should be able to feed vMix easily. https://streamlink.github.io/Not sure it can work with the apps, but certainly from the jw.org website directly Another solution is to use VLC or FFMPEG directly from the video urls on this website Hope this helps Guillaume
VLC 3.x also offers StreamLink like functionally built in. For example, you can enter a YouTube URL into VLC 3.x and it will playout the YouTube video as NDI (with the NDI plug-in installed).
Kane Peterson NewTek
NDI
