Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi there
I've just got a X-keys XKE-124 T-Bar and I'm wondering if anyone has a shortcut and/or activators template they'd be happy to share?
Cheers
Joined: 11/23/2016(UTC) Posts: 330 Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hi Waldron Are you looking for a printable document where you ,can type in, and then cut out with scissors what each key does? If that’s what you want I have an Adobe Illustrator file that I use to do this with little squares where you can type in the Key function.
If you want that I can uoload it tomorrow.
X-keys also has a Microsoft Word version — but I preferred my illustrator version. I think I might still have their Word version if that’s what you want
Rowby
That would be great thanks Rowby. I really appreciate it.
I'm also looking for a template file I can install in vMix for the shortcut and activators if you're able to export your settings?
I'm actually having trouble getting vmix to recognise my Xkeys... anyone got a tip on getting vmix to see it?
Cheers
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
waldron18 wrote:That would be great thanks Rowby. I really appreciate it.
Cheers Yep. Plug it in before you start vMix.
Hi
I tried to upload a zip file with the word doc and adobe illustrator file for x-keys keyboard text caps.
The forum software wouldn't let me do the upload, so if you or anyone wants them just email me at rowbyrowby--AT--gmail.com and I'll send them to you.
Rowby
Hi
Here's a a word file from Xtkeys. A zip file from X-Keys and an adobe illustrator file.
However as I think about this, I don't think the forum will allow me to upload those formats.
So if you want the files (anyone) just email me and I'll send them to you.
Rowby
Joined: 7/9/2016(UTC) Posts: 18 Location: Williamston Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
waldron18 wrote:Hi there
Cheers Hi, Waldron18. Here are my vMix shortcut and activator files for the XKE-124 T-bar or XKE-128. - Dan File Attachment(s): XKE-124 T-bar.zip (213kb) downloaded 108 time(s).You cannot view/download attachments. Try to login or register.
1 user thanked PI48895 for this useful post.
PI48895 wrote:waldron18 wrote:Hi there
Cheers Hi, Waldron18. Here are my vMix shortcut and activator files for the XKE-124 T-bar or XKE-128. - Dan Thanks Dan... That's awesome! I'll load it up now!
Hey there Does anyone know how to clear all activators on the 124 ? I cleared the full list but there are still some lights on…
Thanks !
Originally Posted by: ukcpw Hey there Does anyone know how to clear all activators on the 124 ? I cleared the full list but there are still some lights on…
Thanks ! Hi. Sorry for the late reply. vMix will leave the activators in their last state unless something tells them to do otherwise. You can clear them by unplugging the X-keys or you can use something like our free backlighting utility to clear them and set their default state. X-keys Backlighting Utility
