Feature Requests
vMix Metro compatible Interface and other sugestions
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
hi martin, i have some features to sugest to the next release... *what about to add some Metro compatible interface for windows 8? it would be awesome. *audio dedicated playlist showing id3tag text on the screen, with possibilities below: - choose which tags would be shown on the screen; - show "next" song information, using respective tags; - Background editor (choose an input from vmix input list or import media); - X and Y coordinates for id3tag information; - id3tag transitions (based on the vmix transitions), when switch songs; *on the recording feature, add buttons below: - "import media after recording stops"; - "Pause"; *on existing playlist, add "random" option. thank you martin for your attention and your hard work with v10, vMix is simply a blessing for our productions. regards, melody www.espiritosanto.ccedit: *what about to implement some possibility to take a picture from an input, using it for keying purposes replace that group of colors by another source? this could improve productions where is not possible to use a fixed color or a uniform cloth on the background.
Feature Requests
