bgbenni
#1 Posted : 7 years ago
bgbenni
Germany
Hallo Vmix Community,
i need help.
i wont at a scoreboard source in to Vmix and i don't have any idea how its working ore if it is possible with the api from the scoreboard
The Scoreboard is sending the file with Json.
Maybe some of you can help. i am also happy if it in German ;)
The implementation for the integration for the Events System Listener is done through a service called RESTful, as described below.
The service path for RESTful must be
/events-listener
The service should have the following methods:
Ping
Standard method by scoreboard to "validate" that the service is available. Method HTTP: GET
Path: /ping
Answer: HttpCode 200 if the service is “Available”
New Match Event
Standard method by scoreboard every time they “produce” one of the “events” that scoreboard notified.
Method HTTP: POST
Path: /new-match-event
Post : A JSON that describes the information of the event. This JSON will be described in the section scoreboard Event JSON
New Match Configured
Standard method by scoreboard when a new combat has been set, either by Venue Management or manually.
Method HTTP: POST
Path: /new-match-configured
Post : A JSON that describes the configuration of the Match, this JSON will be described in the section MatchConfiguration JSON
