I am running Vmix 10.0.0.47. Is there any chance there is a memory leak. I note the memory being used is slowly growing during events. After a couple of hours we get low memory warnings from the OS then a crash.
Mike
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi Mike,
It's possible, given vMix 10 is still in preview (beta). Could you provide a list of all the inputs you were using?
Martin vMix
We were using a RTSP input stream from an axis camera and a PNG image that was changing using your new file watch program. We dropped back to version 9 today to test using the xaml input with the dynamic file watch using the .dll you sent. You can watch starting at 8:30 EDT at www.youtube.com/softballoutlet. There should be 4 live streams there. Fields 1-3 are running 10.0.0 52. Field 4 is 9.1.0.37 admin wrote:Hi Mike,
Martin vMix
The system we dropped back to verson 9 seems to be stable. There is definatly a leak somewhere in our config using 10. sportzcast wrote:We were using a RTSP input stream from an axis camera and a PNG image that was changing using your new file watch program. We dropped back to version 9 today to test using the xaml input with the dynamic file watch using the .dll you sent. You can watch starting at 8:30 EDT at www.youtube.com/softballoutlet. There should be 4 live streams there. Fields 1-3 are running 10.0.0 52. Field 4 is 9.1.0.37 admin wrote:Hi Mike,
Martin vMix
