Monitoring Audio Bus A and B
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
is there a way to monitor A and/or B instead of Master only? It seems that there is only a Headphone icon underneath the Master Bus, but what if I want to produce a show with the use of 4 Audio channels (1&2 ambient on Master, 3&4 commentators on A). How can I monitore MA?
I guess there is an easy solution to this, but i can't find it.
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Rinsky wrote:Hi,
I guess there is an easy solution to this, but i can't find it. The way I know is by adding them as audio inputs. When creating an audio input you can use the dropdown to select the busses. Just remove them from the master and click the S to solo.
 1 user thanked Vuurmannetje for this useful post.
I'm not talking about monitoring one single input, but rather a complete BUS/Mix, just like I can monitor the Master with the headphone output.  There is not headphone icon underneath the A and B output. Is this a feature request or is it already possible to also monitor those? Update: 10 months later I finally understood what you meant :-D it makes sense no! Thanks!
