3 Pages123>
vijay6672
#1 Posted : Thursday, May 17, 2018 2:49:14 PM(UTC)
vijay6672
India
Was thanked: 22 time(s) in 12 post(s)
vScheduler 24x7
vScheduler 24x7 is an automated way to schedule programming
(Such as Video, Audio, Image, Photos, PowerPoint, List, Xaml/GT (Overlays), Flash/RTMP, PlayList, and many more) for vMix.
The program allows you to create lists with reference to the timecode, as well as supports most of the functions of vMix.
It is built based on the vMix API.
There are two parts to the program: vManager and vController.
vManager is used to create a list of events each day.
The schedule starts at a set time and runs until the last item in the list is finished.
The files can be saved in Xml format to be edited or aired later.
vController is the brain of the whole operation.
It's responsible for loading and unloading content from vMix, configure if any, and execute given task at the right times.
Together, these two programs make up the vScheduler 24x7 System.
** SALIENT FEATURES **
-Display Now Playing Title automatically.
-Drag & Drop Support (Files/Folders): Compatible with Video, Audio, Image, PowerPoint, XAML, GT, and vMix Preset (.vmix) files.
-Easy Media Splitting (Video/Audio): 1-Click splitting based on the number of parts or time intervals.
-Fix Path: Check for missing paths in scheduled files. Options to either replace with a file of the same duration or remove the file.
-Set a Future Time: If the last scheduled file's end time has passed and you click "Push to Schedule," a warning will be displayed.
-EPG XML: Export the schedule as an EPG XML file.
-Save Schedule to Excel.
-Auto-Title Detection: Change an input number to automatically retrieve it's title from vMix.
-Scheduled events are automatically sent to vMix, even if vController displays Offline/Online Status.
(Also applies to auto-loading the schedule at startup.)
-Schedule Continuity: If any event misses its scheduled path,
vController will remain idle for the duration of that particular event and automatically resume when the next event is available.
-Supports all the available Transition Effects and 4 Stinger Transitions.
-Autoload Schedule at Startup: When vMix is opened, presets are loaded, and vController opens, any pending schedule will automatically resume.
-Bulk Actions in vManager Schedule: Up/Down/Clone/Remove multiple items at once.
-"Always On Top" Feature for vManager: Useful while using drag-and-drop functionality.
-"Always On Top" Feature for vController.
Visit: http://www.sitescape.co.in
Features:
Change Log:
Screenshots:
thanks 9 users thanked vijay6672 for this useful post.
jakefilmpro on 5/17/2018(UTC), tkachuk.alex on 5/18/2018(UTC), AVStream on 5/21/2018(UTC), rowby on 5/23/2018(UTC), avsoundguy on 5/27/2018(UTC), liwarnyamannya on 6/3/2018(UTC), FoxICT on 6/13/2018(UTC), ON.tv Channels on 6/20/2018(UTC), nikosman88 on 4/26/2022(UTC)
AVStream
#2 Posted : Monday, May 21, 2018 7:11:15 AM(UTC)
AVStream
Russian Federation
Is there any support for NDI, or it uses vMix API functions?
Cant wait for a demo )
vijay6672
#3 Posted : Monday, May 21, 2018 11:53:41 AM(UTC)
vijay6672
India
Based on vMix API functions.
thanks 1 user thanked vijay6672 for this useful post.
jelutalica on 5/22/2018(UTC)
sosparabolicas
#4 Posted : Wednesday, May 23, 2018 9:48:23 AM(UTC)
sosparabolicas
When will you make Download available for testing?
vijay6672
#5 Posted : Thursday, May 24, 2018 2:20:24 AM(UTC)
vijay6672
India
Currently under beta testing and expected release date is 30th may.
thanks 2 users thanked vijay6672 for this useful post.
Lennart
#6 Posted : Saturday, June 2, 2018 4:44:04 PM(UTC)
Lennart
Denmark
Was thanked: 16 time(s) in 15 post(s)
Looking forward to it! :)
Nikolay
#7 Posted : Thursday, June 7, 2018 9:14:31 PM(UTC)
Nikolay
The required functions are declared.
very much waiting for release
pabenic12
#8 Posted : Friday, June 8, 2018 8:55:28 AM(UTC)
pabenic12
Any update on release date?
JimJacobs
#9 Posted : Sunday, June 10, 2018 2:32:31 PM(UTC)
JimJacobs
Any idea when this is happening?
sosparabolicas
#10 Posted : Monday, June 11, 2018 11:45:14 PM(UTC)
sosparabolicas
When Will We Have The Download Link?
vijay6672
#11 Posted : Tuesday, June 12, 2018 1:22:54 PM(UTC)
vijay6672
India
Demo version will be released within 1 week
FoxICT
#12 Posted : Wednesday, June 13, 2018 8:20:22 PM(UTC)
FoxICT
Hi Vijay.
It would be an excellent feature to have vScheduler "Loop" the playlist with a toggle button.
Otherwise, look forward to the excellent update in the coming days.
vijay6672
#13 Posted : Tuesday, June 19, 2018 1:26:34 PM(UTC)
vijay6672
India
FoxICT wrote:
Hi Vijay.
Will think over the possibilities.
vijay6672
#14 Posted : Thursday, June 21, 2018 2:40:51 PM(UTC)
vijay6672
India
vScheduler 24x7 Build 2018.06.14 Released.
Build 2018.06.14 Change Log:
(Since last version of MacJaeger)
New functions addition:
-Add Xaml file
-Overlays (1-4) In/Out/Off/Zoom/Toggle
-InputMultiView Set/On/Off/Toggle
-Recording On/Off/Toggle
-Streaming On/Off/Toggle
-External Output On/Off/Toggle
-Scripts Start/Stop/Stop all/Dynamic On/Dynamic Off
-Snapshot
-Set Text
-Set Text Colour
-Set Image
-Countdown To
-KeyPress
-Remove Input
New transition effects addition:
-Merge
-VerticalSlide
-VerticalWipe
-SlideReverse
-WipeReverse
-VerticalSlideReverse
-VerticalWipeReverse
Fixed Photos-Slideshow not playing automatically
Fixed Next file Transition/Playing little early
Save schedule to Excel sheet
Fixed some bugs
FoxICT
#15 Posted : Thursday, June 21, 2018 2:57:55 PM(UTC)
FoxICT
vijay6672
#16 Posted : Thursday, June 21, 2018 3:00:55 PM(UTC)
vijay6672
India
FoxICT wrote:
FREE Demo version (Limited Features - Unlimited Time) available.
Visit: http://www.sitescape.co.in/downloads.html
#17 Posted : Sunday, June 24, 2018 10:11:59 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi Vijay
before I try your app, 2 questions:
- will it work on a different host than the vMix one ? Meaning can we set the vMix host IP address to be used or it is only designed for 127.0.0.1 ?
- does it support UNC path for files ? Example, can I use it on PC1, vMix being PC2 and media being stored on a NAS server (PC3) - eventually on a mapped network drive/folder ? Preferred UNC being \\SERVER\SHARE\FOLDER\FILE, instead of x:\\share\folder\file
Thank you
Guillaume
vijay6672
#18 Posted : Monday, June 25, 2018 2:05:33 PM(UTC)
vijay6672
India
127.0.0.1 is hard-coded in present version;
Different host... will be implemented in next version.
Yes, It supports UNC Path.
Charssay
#19 Posted : Monday, June 25, 2018 4:52:38 PM(UTC)
Charssay
Any One did try it Up ?
How he goes ?
Vijay, 75 USD for the licence it's a little be expensive, did you think ?
Your demo, how many time it last ? It's a fully working demo or some set will not work ?
Thx
thanks 1 user thanked Charssay for this useful post.
Ademola Tella on 11/14/2018(UTC)
vijay6672
#20 Posted : Tuesday, June 26, 2018 5:57:31 PM(UTC)
vijay6672
India
Will think again about that.
Limited Features for Unlimited Time.
Guest (5)
3 Pages123>
