MikeBenke
#1 Posted : 7 years ago
MikeBenke
We are trying to talk to vMix and replay using the HTTP Web API and aren't having any luck yet. Is there some sample code available that could guide us? Here is what we've tried... Any ideas would be much appreciated. - Mike
// Here's some code I found and massaged from
// stackoverflow.com that I use to connect to a URL
// and send a command string.
#include <windows.h>
#include <string>
#include <stdio.h>
using std::string;
#pragma comment(lib,"ws2_32.lib")
void ParseUrl( char *mUrl, string &serverName, WORD& portNum, string &command )
string::size_type n;
string url = mUrl;
if (url.substr(0,7) == "http://")
url.erase(0,7);
if (url.substr(0,8) == "https://")
url.erase(0,8);
n = url.find('/');
if (n != string::npos)
serverName = url.substr(0,n);
command = url.substr(n + 1);
else
serverName = url;
command = "";
n = serverName.find(":");
if ( n != string::npos )
string portNumStr = url.substr(n + 1);
portNum = atoi( portNumStr.c_str() );
else
portNum = 80; // standard port number
SOCKET connectToServer(char *szServerName, WORD portNum)
struct hostent *hp;
unsigned int addr;
struct sockaddr_in server;
SOCKET conn;
conn = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
if (conn == INVALID_SOCKET)
return NULL;
if(inet_addr(szServerName)==INADDR_NONE)
hp=gethostbyname(szServerName);
else
addr=inet_addr(szServerName);
hp=gethostbyaddr((char*)&addr,sizeof(addr),AF_INET);
if(hp==NULL)
closesocket(conn);
return NULL;
server.sin_addr.s_addr=*((unsigned long*)hp->h_addr);
server.sin_family=AF_INET;
server.sin_port=htons(portNum);
if(connect(conn,(struct sockaddr*)&server,sizeof(server)))
closesocket(conn);
return NULL;
return conn;
int SendAPICommand( char* szCommand )
string server, command;
WORD portNum;
WSADATA wsaData;
SOCKET conn;
if ( WSAStartup(0x101, &wsaData) != 0)
return -1;
ParseUrl( szCommand, server, portNum, command);
conn = connectToServer( (char*)server.c_str(), portNum );
if ( conn != NULL )
const char* pszCommand = command.c_str();
send(conn, pszCommand, strlen(pszCommand), 0);
closesocket(conn);
WSACleanup();
return 0;
stigaard
#2 Posted : 7 years ago
stigaard
Denmark
Was thanked: 101 time(s) in 79 post(s)
If you use JavaScript, i have created a utility library that you can use. https://www.npmjs.com/package/vmix-js-utils
thanks 1 user thanked stigaard for this useful post.
MikeBenke on 5/21/2018(UTC)
MikeBenke
#3 Posted : 7 years ago
MikeBenke
Thanks Stigaard, we'll check it out. Our code base is in C++, but maybe Adam will get some ideas from your library..
