Which would have the least latency? GPU Fullscreen out from Decklink Card
Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Just had a new LED board installed in our church. The LED processor accepts a DVI input. (was under the impression it accepted SDI but no).
For the purpose of IMAG, will out vMix PC provide less latency from the GPU (FULLSCREEN) or from a dedicated Intensity Pro PCIe card external Output?
PC Spec: i5 5600K (I think) GTX 750ti 16GB RAM BMD Intensity Pro
Thanks in advance for any advice.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
The gpu output usually has less delay. Using decklink from in to out there's about 6 Pal frames delay.
Test it, put the same source on two monitors and shoot both with a video camera.
