BugviOester
#1 Posted : Saturday, May 19, 2018 7:46:09 AM(UTC)
BugviOester
Was thanked: 8 time(s) in 4 post(s)
Hi there.
Do any of you know, if it is possible to get the tally from vMix to JVC GY-HM200 camera and likes , via the network connection??
I know it does with the StreamStar software.
Best Regards
Barney Box Lane
#2 Posted : Tuesday, May 22, 2018 8:46:47 AM(UTC)
Barney Box Lane
im in the same boat but jvc's a bit all over the place when they say they are working on things, last year they were looking at intergrating ndi and then started concerntrating on tvs :s not the best news when you've just bought into them. Hopefully theres away and they dont end up being another company that just tries to get you to use their stuff (not mentioning any livestream.com related names)
Henny
#3 Posted : Tuesday, May 22, 2018 6:29:53 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
if your any good with coding then take a look at
http://pro.jvc.com/pro/a...ReferenceV107_public.pdf
and some of the core code from
https://github.com/DynamoBen/WIFItally
and you should be able to get something working
