thecloudmediagroup
#1 Posted : Thursday, July 18, 2013 7:19:16 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
I know that Vmix has a video delay but I am not sure it works in the way that I am wanting. Because of audio processing that I am doing, my audio is behind my video. I need to delay my final video output about a second before going to the external output. I played around with the video delay but didn't figure out how to do this. Is what I am describing something that Vmix can do?
#2 Posted : Thursday, July 18, 2013 10:12:01 PM(UTC)
If you use the delay input directly to program you will likely find yourself in a loop (as I believe the delay is set up to save as a clip for the duration you set for use in playback).
The work around would be to use the delay as an overlay in which case you are simply using the delay feature, getting it to match up with the audio might be more of a challenge since the delay is currently only in full seconds.
