Query about resource usage when using a 2nd recorder
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
I currently have a stable setup and am recording in 1920 x 1080 mp4 and also need a lower resolution recording as well. Currently I either post process the 1080 recording or I have sometimes used my second license and NDI and do a second recording. The problem with that is I have to hit Record Start and Stop on both laptops. I would like to upgrade to the 4K version so I can record 2 different resolutions and bit rates at the same time.
I have i7 with SSD.
Are there any issues or additional resource requirements I need to be aware of before making this change ? (I don't want to do this, if it pushes CPU up, or causes some frame dropping in the recordings).
Appreciate any comments and/or experience with others who have made this change.
Grant.
