Fade out Audio on Stinger Transistion
Hi there.
I have 2 video files with embedded audio. I have 1 png animation setup as a Stinger Transition.
When I use the stinger, the audio jump-cuts and its horrible.
Is there a solution to crossfade the audio when the stinger is selected/used?
Haven't had much issues with that, I use triggers, and let that trigger how my audio comes in on the the clip....Do not have vMix open to do a test, but I would try...'On transition in', select 'fade' select audio'....something like that....would have to go on my vMix PC to try it to tell you exactly what to do, but if you experiment, you will get the hang of it, and it will come easy next time....that is how I learnt some of the secrets invMix...by experimenting and reading the User manual....
Joeboe wrote:Haven't had much issues with that, I use triggers, and let that trigger how my audio comes in on the the clip....Do not have vMix open to do a test, but I would try...'On transition in', select 'fade' select audio'....something like that....would have to go on my vMix PC to try it to tell you exactly what to do, but if you experiment, you will get the hang of it, and it will come easy next time....that is how I learnt some of the secrets invMix...by experimenting and reading the User manual.... If I setup a 'trigger' to fade audio out, will that work when it's ''cut'' out as part of the stinger? I'll have a play.
DwFMagik wrote:
I'll have a play.
Hmm. Still looking for a solution to this one.
