krayg123
#1 Posted : Wednesday, July 17, 2013 11:25:22 PM(UTC)
krayg123
I am using the trial version at the moment, and it looks good. However, I can't see if it is possible to output to multiple external devices at the same time.
In my main computer, I have 4x Decklink Intensity Pro cards - 3 are HDMI input, and 1 is composite out. Unfortunately my trial is not on this computer with the cards, as it is used as a production machine, so I have had to install on a machine without the intensity pro cards.
Question: I want to be able to stream to WMS at the same time as outputting to a intensity pro card. Can I do this? The idea would be to use expression encoder to pick up the vMix output via virtual device, and encode to WMS. At the same time, I would be outputting to one of the intensity pro cards which displays the output on a projector. Is this possible with vMix?
Thanks.
Edit: It looks like the v10 preview may be able to? Is this the case?
krayg123
#2 Posted : Monday, July 22, 2013 9:55:31 PM(UTC)
krayg123
Anyone?
Egriswold
#3 Posted : Tuesday, July 23, 2013 9:33:00 AM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
short answer "yes"
Vmix has three main outputs the program switch can be sent to. first the "Full Screen" button sends output to secondary port on graphics card. Second and third are activated by the "External" button at bottom of interface. The External is setup by accessing the settings panel and going to the external video tab. You can see more on all these controls and outputs in the help file.
thanks 1 user thanked Egriswold for this useful post.
krayg123 on 7/24/2013(UTC)
